At almost $300 a gallon do you get a gold bar with it as well? Sarcasm aside that seems like a very expensive gallon of paint which would get at least 2 coats maybe 3 and as it is a clear coat i would think you might only get a few months to a year in the areas that get lots of scuffing. At least those are my opinions based on clear coats i have used on vehicles before. Maybe this one is different or more robust than clear coats from the past. Can’t wait to hear from a cybertruck owner who has used it for some real world experience with the product.ProtectaClear® by Everbrite Coatings has been used for decades to protect stainless steel on various surfaces worldwide. From automobiles, trailers, buildings, architectural accents all the way down to jewelry, it is one of the most durable clear coatings on the market, able to withstand even the harshest of elements.
For the Cybertruck it is the only coating that will not change the original finish coloring while protecting it from fingerprints, tarnish, road salts and other corrosion. Check out our website for more information on how ProtectaClear can protect your Cybertruck's factory finish. Restore & Protect Your Tesla Cybertruck from Corrosion (everbritecoatings.com)
I am in Kelseyville, no problem going to Sac for a trial. Should have my CT by the end of March.Unfortunately, there aren't many Cybertrucks out yet and I don't personally know of anyone who has received theirs yet. I am over number 1 million on my reservation, so it's going to be a while. If anyone is close to Sacramento, CA, I am happy to apply some as a test for all to track the results on.
A truck will take about two quarts of coating, so only $200 and the finish will last for years before needing a touch up.
Speaking of moving on if this does not "work" to people's satisfaction. What is the removal process like.Oh, a DIY wrap? That sounds complicated! Give this a try and if you don't like the results, then move on to your wrap.
I have used some industry paints that are over $500 a gallon, makes it really painful when you accidentally spill some.At almost $300 a gallon do you get a gold bar with it as well? Sarcasm aside that seems like a very expensive gallon of paint which would get at least 2 coats maybe 3 and as it is a clear coat i would think you might only get a few months to a year in the areas that get lots of scuffing. At least those are my opinions based on clear coats i have used on vehicles before. Maybe this one is different or more robust than clear coats from the past. Can’t wait to hear from a cybertruck owner who has used it for some real world experience with the product.
You will want to use ProtectaClear for the stainless steel. We are putting together a kit that will be available this week. I will post here when it is available.It looks like you have two different products that could work for the cyber truck coating that is referenced on your website Which product do you recommend for the cyber truck?
After doing the calculations you should only need two quarts of coating, so about $200 in product. I can guaranty you this is different than what you have used in the past. It will last for years. Plus seeing that wraps are $8K-$10K, this is a steal!At almost $300 a gallon do you get a gold bar with it as well? Sarcasm aside that seems like a very expensive gallon of paint which would get at least 2 coats maybe 3 and as it is a clear coat i would think you might only get a few months to a year in the areas that get lots of scuffing. At least those are my opinions based on clear coats i have used on vehicles before. Maybe this one is different or more robust than clear coats from the past. Can’t wait to hear from a cybertruck owner who has used it for some real world experience with the product.
It will stay on at temps above 400°, much hotter than the exterior of your Cybertruck would ever be.Ok, Do you mean Gas off is volatilization temp correct? I meant to ask at what temp will the coating deform in a plastic sense where it would be more easily damaged? I look forward to purchasing some of this material to test prior to using it when I have my CyberTruck.
It will be fully cured in 4-5 days. So ideally you can garage it for that time, but if not and you get some debris that damage it, it is self-annealing, so always fixable.So how long would you recommend allowing the truck to cure before driving it? I know it's not exact, but dry to the touch doesn't mean that no road debris will stick to it. Are we talking days or hours at ~72F?
Such an amazing statue! I am assuming if you turn the crank it moves?! I love the finish too.Yes I've placed exterior SS public sculpture in various cities. Sometimes people want to know what to use on it. It is a broad subject and coatings are not usually needed for SS outdoor sculpture.
However on the CyberTruck the finger print issue makes a coating useful.
Renaissance Wax is usually the top product used on archival metal and even Stainless Steel. It also has a very strong odor when applied, that then dissipates. Fingerprinting is certainly vastly reduced. How does ProtectaClear compare to Renaissance Wax?
I agree $200After doing the calculations you should only need two quarts of coating, so about $200 in product. I can guaranty you this is different than what you have used in the past. It will last for years. Plus seeing that wraps are $8K-$10K, this is a steal!
We have had some volunteers so we should have videos available by around the 15th and will post them.
DIY wraps in vinyl runs around $3k and ppf around $2.5k. Those prices could go down or up depending on who takes office next year. You can double that (or more) to have Tesla do it for you (only 3 options at moment of this writing black, white or satin finish). So $200 and applying it yourself and having essentially the satin ppf wrap %10 of the cost of the ppf is definitely cost effective. I would venture to guess anywhere from 2 to 8 hrs would need to be dedicated to prepping and applying the product depending on how skilled you are and how thurough.After doing the calculations you should only need two quarts of coating, so about $200 in product. I can guaranty you this is different than what you have used in the past. It will last for years. Plus seeing that wraps are $8K-$10K, this is a steal!
Tesbros DIY vinyl runs $1599I agree $200
