Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories!
GFleck
Greg
Indianapolis Indiana
2023 Model Y, 2024 AWD Cybertruck
2.For the custom bed frame, maybe we can create something similar to an inflatable mattress that fits the second row. Do you prefer a bed frame rather than an inflatable mattress for the second row?
Personally I prefer and am anxiously waiting for someone to make an inflatable version of this, like the one pictured.
Minnesota
Cybertruck Tri-motor (will do quad)
A Propane tank holder that can use the L-track wall to anchor the tank from moving around in the bed.
DJAlan2000
Alan
Oxnard, CA
Tesla Model Y-LR and soon our CyberTruck F-series
Thanks for your comments! ? ? ?
1. Truck bed 'unloader'(This effect? automatic instead of manual cause automatic is more handy)
2. DUAL folding/storable ramps(just like this? You prefer DUAL ramps had 'spars' that would lock them together in place)
4. As for the vault cargo Panel, just like this, placing it in this position? You want it to fold into the vault when not in use and fold out when needed, with additional storage features for tools or coffee, etc.?
I hope I understood your request correctly. I've added the other suggestions to my to-do list and will work on providing the perfect solutions for you in the near future! Feel free to share any additional needs or ideas you have!???
Ramps I was thinking about would be more like this:
Cybercab Robotaxi Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories! 1722365624584-g3
Just something to keep the two ramps separated so when you are loading/unloading something they wouldn't be able to 'move apart' (like I have seen happen to other trucks with two ramps) at the bottom/top causing things to end up falling off the ramps...
They would need to be adjustable for different 'widths' of course...
As to the 'unloader' pic you shared, yes, that's what I was talking about, but rather than a 'hand crank' one that you would plug into one of the outlets on the CB...
The 'fold out' side panels you pretty much get the idea... Of course they would have to lock down to the 'rails' inside, then be able to come up and over the sides (with rubber padding to protect?) and then end up as a 'tray' that is flat and level on the outside... Wouldn't need to be heavy duty as it would/should/could be just there to hold tools you are using (not a chest) and maybe a water bottle, coffee holder kind of things... Mostly it would just be flat, about 10-12" wide and have a few 'holes' drilled in it for things like screwdrivers, hammers, etc... with maybe a couple of 'hangers' for other things too...
Maybe something like this (when opened up and 'over the side') but with a way to hold tools, parts, etc. to keep them separated as needed. Wouldn't even have to be 2 of them, just one side would work... The 'box/tray would only need to be used when it's opened up... It would be empty when folded into the back of the truck... sort of a combo of the box below and one of those tool holders for rakes and shovels and such that you see gardeners trucks have (except not for long handled items, but for short ones).
Cybercab Robotaxi Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories! 1722366897749-10
jonesw67
Warren
AR
Cyberbeast
How about a support bar that connects to the Vault L-Track and runs the width of the Vault. You can then add a number of them along the bed where needed and place anything on top of them to create a new level.... such as boards for camping.... leave as rails transporting as a second level, and each time still have the space underneath.
Cyber_95
Honolulu, HI
An under-screen bin/storage tray, but one that goes full width of the screen, similar to this for the Model 3:
Cybercab Robotaxi Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories! 1722412292518-nj
Teslaunch
Teslaunch
Cybertruck model 3 highland model y
Thanks for considering the ideas.
#1 - Yes, a bug screen like what you showed in the pictures. It can attach to the same groove that slides the Tonneau cover. It’ll be very useful.
#2 - Inflatable is good. A solid frame might also be ideal. I have seen someone create a bunk bed there with seats folded. It’s a very versatile space with some unique opportunities to create good sleeping space. Probably you can start with inflatable and depending on the demand do the solid one?
#3 - Sprinter Van Rebel has an inflatable one for the driver seat. Check it out. Even if we create something for a child or petite person, it’ll be a win.
I wouldn’t recommend investing too much on mattress options for bed. People who use truck like a truck will not have a clean truck bed. It’ll be filled with dirt and debris. I don’t know how many people will keep the bed clean enough to put a mattress. Instead of a mattress, you can come up with a regular tent for the bed. It need not be an attached unit like the one Tesla sells. You just put the tent base in the bed and assemble it similar to any ground tent. The exception is that the size and fit will exactly match CT’s bed. Then you tie down to hooks inside the bed. This will be super useful. A tent like this with couple of inflatable mattress inside the CT will be a game changer. A family of four can easily camp anywhere, including in wet and damp areas. Ground tents don’t cost much. Inflatable mattresses are also reasonable. This solution works price wise as well. It’ll be a killer product! In the future, you can add more accessories such as awnings from the hitch connector, etc.
Wow! Regarding the bug screen and inflatable bed mat for the rear seat, we're already searching for products that match the right dimensions and hope to bring them to market soon! As for the tent, we're working on a Cybertruck tent model, but your idea is fantastic. ????An affordable alternative is definitely something we excel at and can bring to market quickly. ?(y)I'll make sure to push the process forward! Any updates will be shared on the forum as soon as possible.
If you have any other ideas or suggestions, please continue to share. We're always excited to hear your valuable and brilliant thoughts! ? ? ?
Teslaunch
Teslaunch
I think someone else mentioned it, but something that is much taller and is level with the center console would be nice. There's SO MUCH empty space between the top of the center console and the floor that could be used by a well-thought out accessory/insert, why just settle for the floor?
Absolutely! We've heard from several owners on the forum who are interested in creating a storage box or trash can for this area to prevent items from falling onto the driver's side floor. Higher storage space is definitely something we're considering. Additionally, we think that in the future, Tesla might design this space as a refrigerator since it’s an ideal location for one. What do you think?
Cybercab Robotaxi Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories! TESLAUNCH-10
Teslaunch
Teslaunch
1. The dividers would be for those of us that bought (or buy) the tesla under seat storage that no longer comes with any dividers. They would be similar as the ones you have in your picture.
2. This would be like a thin but rigid insert that goes into the storage locker under the vault so that when you want to use it for ice or temp storage other than cleaners/chemicals/tools etc. you can just lift out what’s in there and have a clean area to make use of.
3. ?
Thanks for providing further details! ? ? ? Very Useful! For rigid dividers, we don’t currently offer anything similar, but it’s something we could consider developing in the future. For now, we have an Insulation Cooler Bag that can fit into the under-vault storage space. It has a zipper to keep it closed and should protect against contamination. Would this meet your needs for the time being?
Cybercab Robotaxi Seeking Your Input: Help Teslaunch create more amazing Cybertruck Accessories! Teslaunch Rear Truck Bed Lower Insulation Cooler Bag For Tesla Cybertruck
Teslaunch
Teslaunch
I'd like to see something larger that would at least come up from the floor to level with the seat bottom. Built from a rigid matching CT material and more permanent with closed storage. I'd rather not have my sunglass case, chargers, tissues, gum, etc visible.
The one you pictured appears to be a soft material, probably comes flat packed and all bins are open.
Got it, noted down!✍✍
?Material: Similar to CT's, but a bit sturdier.
?Height: More permanent with closed storage.
?Would be great to have a cover or something to keep your personal items out of sight.
???Feel free to share any other thoughts and suggestions. Your feedback is incredibly valuable to us!
Teslaunch
Teslaunch
Looks like we underestimated the market previously by focusing only on the inflatable mattress for the vault. :unsure::unsure:There's clearly a significant demand for a rear seat mattress too! Perhaps a product like the one in the picture, which can be used in the rear seat and, if needed, can be extended into the vault, might be more economical and practical. I’ll expedite the development of this product. Thanks for your confidence and suggestions! Feel free to share any other fantastic ideas you have!;);)
Teslaunch
Teslaunch
Check out this post I just made that gives a good overview of what I would love to see in a simple custom cybertruck pop up tent! https://www.cybertruckownersclub.com/forum/threads/camping-set-up-while-i-wait.21324/#post-372547
Great thread by the way ?
I carefully reviewed your post yesterday, and that tent is definitely a very cost-effective choice that doesn’t affect your driving!(y)(y)(y)(y) We're currently calculating costs to see if we can offer a similar setup or even a better solution. Thanks so much for sharing your insights and suggestions. I feel like we Tesla folk truly love life, camping, and everything about it! Feel free to share any other fantastic ideas you have!:love::love:??
tmeyer3
Trevor
CA
www.meyerwine.com
Computer Scientist, Vintner
I personally I have no need for a refrigerator that small. I have an ecoflow one already that stores a lot more than one that'd fit there could do. Also, (personal preference) I don't like putting my fridge in the cabin if I can help it as it does exchange heat into cab, not much, but if I have a bed I'll put it there.
Ideas are the standard things, cup holders, tiers (2?) of organizer trays, etc
Teslaunch
Teslaunch
Oh, I see. ✍ ✍ A small fridge might only meet the daily beverage needs of the owner, while a larger fridge is more suitable for camping and other extensive needs. It does make sense that having a fridge in the cabin can cause it to heat up, and you've thought this through quite well. Alright, tray and cup holder designs are a must-have. I'll spend some time with my team to see how we can design them in a more reasonable way. Also, thank you so much for your ideas and suggestions—they're really helpful!(y)(y)
