New top mounted LED light bar with RGB DRL in development
LuckysFabShop
Houlton WI
beast
Our 52" Light bar is in development. Specific built 48 volt light bar with built in RGB accent light to match your interior accent lighting. Light bar and RGB accent lighting can be controlled via your phone with provided app.
Things to note:
* Mount is not final. We are working on multiple designs. But we want it to compliment the trucks lines.
*Power connects to the factory power on the roof. Once connected and turned on you then can control the RGB with your phone and change the colors.
*Light bars shouldn't be crazy expensive so we are working to keep affordable.
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152216413_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152319036_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152304726_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152335606_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152238369_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152351485_HDR
Cybercab Robotaxi New top mounted LED light bar with RGB DRL in development IMG_20240722_152050604
Art138
Art
Weston,Florida
MYP,Ferrari Pista,Ford GT & CYBERBEAST
Is the connector to power the system compatible with the plug found under the roof side trim? or is splicing required?
LuckysFabShop
LuckysFabShop
Houlton WI
beast
Yes. It will connect to the factory light bar power supply. Once connected and turned on you can use your phone to control the RGB.
reaction26
Arash
CT, MXP
Program Director
Things to note:
Looks amazing, any update on cost and how long it will to install it?
reaction26
Arash
CT, MXP
Program Director
We are trying to keep it around 500 or less. Install would be 10-15 minutes to an hour depending on your abilities.
Any chance I could be your 2nd one with it and then advertise it so you could sell more? I think we should be able to get a few more people then bring the price down? Your thoughts? I think it seems pretty straight forward on the install.
LuckysFabShop
LuckysFabShop
Houlton WI
beast
The mounting brackets and light bar isn't made to order. Couple hundred will be made in each run. But we can definitely work with you to promote the product.
rlhamil
Richard
Glen Burnie, Maryland
2002 Trans Am WS6, 2007 PT Cruiser GT
Hmm. Forward facing light colors blue, red, and green are problematic; blue exclusively for police, red either emergency vehicles or confuse-able for tail lights, green just plain confusing. Yellow or white are ok. Pastels might be ok if there's no confusion. And of course off-road, who cares, except faking a police or emergency services vehicle appearance isn't good even there.
Heck, even interior accent lights I'd probably run dimmest white or red; although blue is said to be more calming than red, I expect that red would interfere less with night vision. To me, it's more of a practical than taste or style choice, although others are of course free to do whatever they please that the law allows.
Cyberbully
Ron
Monterey, CA
2024 Cyberbeast
Self employed
Is the RGB part wired seperately? Run off the same 48v wiring?
reaction26
Arash
CT, MXP
Program Director
perfect how would i be able get in touch with you?
