Ground-Breaking Method To Make Graphene From Garbage Is Modern-Day Alchemy
More from Rice University
Graphene is a hot subject in science right now. It’s a honeycomb sheet of carbon just one atom thick, 200 times stronger than steel, more conductive than copper and can stretch up to 125% of its original length. One day in the not too distant future, it will revolutionize everything. It’s even thought that the all-important tether component in the long-awaited space elevator project will eventually be constructed from graphene.
There are a number of different ways to produce it (using either what’s called a top-down or a bottom-uptechnique) but most methods currently involve a painstaking and expensive chemical process. However, it’s believed the graphene industry will be worth at least $350 million by 2028.
So when researchers at Rice University announced in a paper published in Nature that they had devised a method to make graphene from household refuse, it seemed like a modern-day equivalent to alchemy had been discovered.
Cybercab Robotaxi Ground-Breaking Method To Make Graphene From Garbage Is Modern-Day Alchemy 960x0
At just one atom thick, graphene is an incredibly lightweight and conductive material
NGI/MANCHESTER UNIVERSITY
The study shows that a split-second, super-hot flash of electricity focused on any item containing carbon — including a plastic water bottle, a worn out rubber tire or even food waste — reorders the carbon atoms to produce graphene. All chemical bonds are broken, forcing all the other elements to escape as gases, leaving behind a super-strong lattice of carbon just one atom thick.
The burst of energy that heats up the item to over 5000°F is so precisely focussed that making half a kilogram of this “flash graphene” would only use the same amount of energy as running a standard dishwasher for 30 minutes. No solvents or chemicals of any kind are used.
“Carbon is in everything around you, everything you see, even us and the things that we eat. We are carbon-based lifeforms,” James Tour, Professor of Chemistry at Rice University and co-author of the paper, told Forbes.
“So you put some household trash between two electrodes, you hit it with a few hundred volts and a hundred amps and it blows out, every other element distills or sublimes out. And all you're left with is the carbon. And the carbon takes the most stable formation possible, which is graphene,” Tour said
The concept of converting waste into graphene isn’t new, but this is the first time scientists have made the procedure possible. If this (bottom-up) flash graphene process can be efficiently scaled up, the breakthrough will transform the materials industry. Transforming the carbon found in food or trash into graphene prevents that carbon from reentering the atmosphere as those items decompose.
The potential of graphene is already being noticed. According to Tour, Ford Motor Company buys as much as it can get. “As of February 2020, it’s in every Ford motor vehicle. Graphene is in the foam in the seat. Graphene is in the seat covers. Graphene is in the insulation under the hood. And now that the price is going down, it's going to be in more places,” he said.
Downtown Hong Kong perfectly illustrates how much concrete is used in cities worldwide
ADOBESTOCK
However, the biggest impact graphene could have in the immediate future is in construction, by adding it to concrete. Cement production produces 8 percent of the world’s carbon emissions, roughly three times as much as the aviation industry. If all the cement in the world was reinforced with graphene, the subsequent saving in concrete manufacture would be the equivalent of stopping the annual carbon emissions of Brazil.
“If you put a tiny amount of graphene into concrete, 0.03%, you increase it’s compressive strength by 25 percent, which means you can use a quarter less concrete and by just doing that you could reduce the global CO2 levels by 2 percent,” Adrian Nixon, Director of Nixene, a chemical research company that works in association with the National Graphene Institute, told Forbes. Based in Manchester, England, this is the largest organization dedicated to the development of graphene in the world.
“The scale of this is such that concrete is the biggest, most consumed product in the world after water. So there's about 8 billion tons of concrete consumed each year,” Nixon said.
Graphene is the only material strong and flexible enough to make a space elevator tether
GLENN CLOVIS
And of course then there’s the source material: garbage. Potentially, waste tips could be mined for material to use. Mountains of plastic could be reduced to their component molecules and repurposed into something useful.
Tour, who is also a scientific advisor for Universal Matter, a company trying to produce flash graphene commercially, points out that by using food waste, emissions from methane, a potent greenhouse gas released as food degrades in landfills, can also be reduced.
“We [Rice University] have grant from the Department of Energy to make one kilogram a day converting coal into graphene. So the DOE is trying to keep coal mine jobs available. Well, you got to be able to do something in very large scale and turn coal into something useful,” Tour said. “So in my lab, we are tasked with making a kilogram a day. Doesn't sound like a lot, but it's a lot for us. And then the company [Universal Matter] is scaling a process where they're going at trying to make a ton a day within a couple of years.”
Source: FORBES
Newton
Newton
East Bay Area, CA
can some1 give me a bunch of money? :ROFLMAO: (im joking btw, its not the same thing)
Cybercab Robotaxi Ground-Breaking Method To Make Graphene From Garbage Is Modern-Day Alchemy Candle-soot_410_tcm18-210943
I know what makes graphene special is the fact thats its 1 atom thick
I wanna see how they would actually make it into a usable product.
Actually, it is. If you take that slide and lightly press a piece of scotch tape onto the carbon smudge and then onto a piece of paper you will leave a layer of graphene, one atom thick, on the paper.
Note that it was at Rice that Buckminsterfullerene (the spherical equivalent) was discovered by the math department. Fascinating story. The chemists blasted carbon and the mass spec showed C60 in the debris. They couldn't, after considerable head scratching, figure out how 60 carbon atoms could form a molecule. So one of the chemists called a buddy in the math department and asked what had 60 points connected together. "A soccer ball" says the math guy and the rest is history.
Newton
Newton
East Bay Area, CA
Hmm, pretty cool!
cybrtrk_maybe
Gary
Colorado
RAM 1500 promaster, Honda CRV
Software Engineer
This sounds like an incredible breakthrough. Literally turning trash into treasure.
